P0135 = HO2S ( Heated Oxygen Sensor ) heater circuit malfunction.
P0758 = Shift Control Solenoid Valve "B".
Test would have to be performed to verify the source, could be a faulty sensor/solenoid . Check if any of the wireharness are loose or contaminated.
When did the Check Engine Light started showing?
It is a separate issue with the D light blinking.
Jul 28, 2010 at 6:59 PM
