i have a 98 cl and the oil belt just broke. had it replaced and ran a diagnostic on the car. results came back sayin that i had low effeciency on the catalytic converter, problem with the v-tech solenoid and the srs light keeps coming on. when i start the car, the lights on the panel remain illuminated, but when i step on the gas, they start to flash.
after some time, ran another diagnostic and it said that everything was fine, but the lights on the cluster continue to give the same problem. can you please give me some kind of idea as to how to fix this problem. thank you kindly.
i also have a compustar alarm system with an auto start feature which has not been starting as of a couple of months proir to this problem. would that have anything to do with the problem as well. thank you kindly.
Jul 18, 2008 at 10:33 PM
