1998 Acura CL EGR valve
1998 ACURA CL
160,000 MILES • 4 CYL • FWD • MANUAL
LANEL08
My check engine light came on for the EGR valve code #P0401 and i replaced the EGR valve. The light went off for about a week but now is back on. I heard you can clean out the EGR passage but i dont know where the passage is on the 2.3L, I have found ways to do it for the 3.0 but not the 2.3. Any ideas on what i should do or where to find the steps on how to clean out the passage if thats what wrong? Any information would help.
Feb 5, 2009 at 7:37 PM
F4I_GUY
  • 3,302 POSTS
The passage is where the EGR soleniod/valve mounts onto. You can use a good aerosoil cleaner and a pick/scraper set to remove stubborn carbon. Just try not to drop any carbon into the manifold.
Feb 16, 2009 at 7:45 PM
JRECENDEZ10
I drive a 1998 ACURA CL 2.3 check engine light went on for the egr valve i replaced it twice, the light went off n about a week later it went back on. I cleaned the passage way and it went off then about a day later returned reading the same code p0401. how can i fix this problem?
Nov 26, 2012 at 9:01 PM
