Actuator problem
2004 CHEVROLET SILVERADO
232,000 MILES • 6.0L • V8 • 4WD • AUTOMATIC
OLDFATPREACHERMAN
I replaced the actuator for the drivers side, the motor stopped working in the old one. Set it on cold and it seemed to work fine. But when I drove the truck, the actuator when from cold to hot and stayed there. When I restart the motor it goes back to cold for about two minutes and then to hot and stays there. I pulled the fuses and reset them but that did not help. I have restarted at least a dozen times and always the same thing. Got the actuator from Amazon, did I get a bad actuator or is there another sensor somewhere.
Sep 17, 2017 at 1:01 PM
STEVE W.
  • 15,113 POSTS
Did you follow the reset procedure once it was installed?
You did not try to test it prior to installing it did you?
Calibration procedure:
Clear all DTCs.
Place the ignition switch to the OFF position.
Install the HVAC actuator.
Connect all previously disconnected components.
Remove the HVAC/ECAS fuse for a minimum of ten seconds .
Install the HVAC/ECAS fuse.
Start the vehicle.
Wait forty seconds for the HVAC control module and actuators to self-calibrate.
Verify that no DTCs have set as current DTCs.
Sep 17, 2017 at 6:23 PM
