You never gave me a high side reading. I need that reading and the low side while the A/C is on.
Below is the description of the code and attached is the flow chart for determining the failure.
Climate Control System - Vehicles With: Dual Automatic Temperature Control (DATC)
Pinpoint Test(s)
P0532, P0533
Normal operation and Fault Conditions
The A/C (air conditioning) pressure transducer receives a ground from the PCM (power-train control module). A 5-volt reference voltage is supplied to the A/C (air conditioning) pressure transducer from the PCM (power-train control module). The A/C (air conditioning) pressure transducer then sends a voltage to the PCM (power-train control module) to indicate the A/C (air conditioning) pressure.
DTC Fault Trigger Conditions
Possible Sources
Wiring, terminals or connectors
Visual Inspection and Diagnostic Pre-checks
Inspect for loose or corroded PCM (power-train control module) and A/C (air conditioning) pressure transducer connections.
Jul 27, 2020 at 4:22 AM
