Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
Crown Victoria
Interior
Gas Pedal
Sensor
Replace/Remove
Accelerator pedal not working
2010 FORD CROWN VICTORIA
226,000 MILES • 0.5L • 6 CYL • 2WD • AUTOMATIC
MARSHA50
MEMBER
FOLLOW
I replace the pedal sensor, but it still will not work.
Sep 28, 2019 at 3:34 PM
CERTIFIED EXPERT
Good evening.
Is that the issue? Were there any codes set for this? If there was, I need the code.
The TPS is the most common issue for no throttle response.
Beyond that, the throttle body may have to be replaced.
Sep 28, 2019 at 4:07 PM
