Acceleration taking a while to pick up speed
2007 SATURN ION
165,853 MILES • 4 CYL • 2WD • AUTOMATIC
JOHNSONSIMON23
when i am at a red light or going from idle to accelerating the car takes like 10-15 to pickup speed but the rpm's rev up. After i get speed its okay or if i am on a high it's okay, but it only happens when i stop and then go to drive again.
Mar 1, 2020 at 2:56 PM
Good evening,
It sounds like the catalytic converter is clogged not allowing the engine to breathe.
It will give you low power. You need to do a back pressure test. You could remove the front O2 sensor and drive the car and see if it runs better. That will confirm the converter.
Mar 1, 2020 at 4:28 PM
JOHNSONSIMON23
could it also be spark plugs or coil pack?
Mar 2, 2020 at 3:43 AM
If it was one of those, it would misfire and the check engine light would be flashing on and off.
Mar 2, 2020 at 4:29 AM
JOHNSONSIMON23
okay and is it cheap to fix a clogged converter?
Mar 2, 2020 at 12:52 PM
It needs to be replaced, not cleaned. You cannot clean a catalytic converter.
Mar 2, 2020 at 12:57 PM
