So here is the deal. I filled car up with gas went home about fifteen miles car drove fine next morning started car it would not accelerate or rev barely get up to 2000 rpm's. also, I heard what sounded like a vacuum leak. so long story short I replaced throttle body thinking this was the problem replaced all six coils and intake gasket checked fuel pump and filter both good put it all back together and same problem, so I could still here the vacuum leak found out that the EGR gasket was leaking. I took it off and used a make a gasket sealant put the whole thing back, but at this time I had battery disconnected so after i put it back together and cranked it sure enough had full power for about five minutes, so got out car and noticed the EGR valve leaking more but did not hear it leaking when first started car so do you think a leaking EGR would take the power out complete so much I could not even get over five mph ? And did the make a gasket work for the first five mine are did the computer reset it self?
Aug 11, 2016 at 7:43 PM
