Every thing was fine but when accelerated it went down instead boost up and some time engine shutdown
2000 DAEWOO MATIZ
115,000 MILES • 0.8L • 3 CYL • 2WD • MANUAL
SUMRINA ZAFAR
We overhauled engine, new piston and ring, new valve, new fuel pump, fuel injectors, new spark plugs.
When we started engine it was normal at start on idle.
Nov 25, 2019 at 10:14 PM
It sounds like the exhaust system is clogged. To be sure here is a guide to help us confirm the issue:
Nov 27, 2019 at 2:46 PM
SUMRINA ZAFAR
Exhaust all okay. But decline of combustion still there.
Nov 29, 2019 at 10:14 AM
It sounds like the camshaft timing could be off a tooth. Lets do a compression test to see if the engine is okay. here is a guide:
Dec 1, 2019 at 1:25 PM
