The car sat for a little over a year. no clue if it was making this noise before that.
i was doing some WOT pulls to clear out cobwebs after i had put fresh oil in and ran a full tank of gas through, the car seemed a little unresponsive. had a friend suggest that it may just need to be opened up and ran a little to clear the cobwebs, break some things loose.
That's when i noticed When i take off, if i just roll into the throttle and let the motor slowly build rpms, the whine is sort of there but barely noticeable. If i floorboard throttle, around 3-3500 rpms i start to get a whine that starts, then stays until throttle is let out.
Doesn't do it at lower rpms. doesn't do it unless hard acceleration. it doesn't sound like a transmission whine. It's almost a mixture of a whine and a squeal. doesn't just sound like intake suction either.
any ideas on where to start/how to diagnose this?
Apr 15, 2023 at 8:47 AM
