Acceleration issues, acts like it is in limp mode? transmission code P17F0
2014 NISSAN PATHFINDER
150,000 MILES • V6 • 4WD • AUTOMATIC
NMDESNOYERS
The alternator was replaced a week ago. When I first picked it up it started jerking when going home. I figured it needed a little bit of driving to fix itself. The gas mileage tanked (19.5 down to 14.8) so I tried fuel injector cleaner. After a little bit of driving slow and steady it felt a lot better and didn't idle rough anymore and the MPG went back up to 18.3. But now it drives weird. I have a hard time accelerating when at a stop. I have a much harder time with enough power to go up hill without a lot of resistance. I can drive fine when I get into second and third gear but if I try to drive on a highway at anything above 65 there is resistance. The check engine light is not coming on so I'm really confused where to start. It drives almost like it's in limp mode from what I've read online.
Dec 13, 2023 at 4:09 PM
DR LOOT
  • 2,311 POSTS
It sounds to me like you're having fuel pump problems. I suggest you get the fuel pressure checked. If it had a fuel filter, I would replace it. Your failure of an engine light coming on indicates also that it's fuel-related issues. The computer won't tell you if your fuel pump's going out or if your pressure is low. So, check the fuel pressure and let us know.
Dec 13, 2023 at 6:37 PM
NMDESNOYERS
I took it in for a diagnostic to the shop I usually go, and they said fuel pressure is fine but there's a transmission code P17F0.
Dec 14, 2023 at 9:32 AM
DR LOOT
  • 2,311 POSTS
Thanks for supplying the code. That is a valve body malfunction, did you have the transmission flushed lately or did you do a transmission service yourself? Sometimes this code is set when small piece of metal or some foreign object in the transmission has stuck one of the solenoids open. It isn't that difficult to drop the valve body. I can step you through it. Let me get a little bit more information on that and I'll get back to you.
Dec 14, 2023 at 11:16 AM
NMDESNOYERS
No, I haven't had anything done recently except the alternator replaced last week. The last time there was work done was 1.5 years ago.
Dec 14, 2023 at 11:24 AM
The P17F0 code on a 2014 Nissan Pathfinder is typically related to a transmission issue, which can cause the vehicle to go into limp mode.
So, I can tell you these transmissions had big problems with the belt burning up, can you please remove the transmission oil pan to inspect for metal in the pan and also, we can check the fluid condition as well. This can help us determine if the transmission is bad. Here is the fluid type and how to do the job.
Fluid Types
Transmission Fluid
Type .................... Genuine Nissan CVT fluid NS-3*
*: Use only Genuine NISSAN CVT Fluid NS-3. Using transmission fluid other than Genuine NISSAN CVT Fluid NS-3 will damage the CVT, which is not covered by the NISSAN new vehicle limited warranty.
Capacities
CVT Fluid
Capacity .................... 9-1/4 qt (8.8L)
Check out the images (below). Let us know how it goes.
Dec 14, 2023 at 1:24 PM
