Yep, these codes can come up when the engine oil is low or needs to be changed, so I would do that first and then clear the codes there is a chance the camshaft actuator oil control valve is clogged, or the actuator itself has gone bad.
P0022 - "A" Camshaft Position Timing Over-Retarded (Bank 2)
Here are diagrams to help you understand what is going on. Check out the images (below). Please let us know what happens.
Jan 6, 2025 at 10:56 AM
