Hi, when i try to run when the engine is cold, it hesitates. The idle move by itself. the engine it's like going to stop if i don't press hard to the accelerator. if i push slowly it is looks like it is going to stop. My garage changed the spark plugs. the gas is super or supreme gas. The injectors are clean. The mechanic cleaned the throttle and the sensor, air filter new, crankshaft sensor new too but the same result. only when the engine is cold.
Mar 29, 2022 at 8:12 PM
