Those voltage readings are all within range, on pins 3,4 CAN C Private Bus +/- and pins 7,8 CAN C +/- you will only get a very rough average of the CAN bus voltages using a multimeter, a meter is not nearly fast enough to measure CAN bus data.
To see if there were good data packets coming from the module you would need to scope those wires with the connector unplugged but the module still powered up.
you verified the module has power and ground.
The voltage you're reading on the CAN bus wires could be from any module on that specific network, not necessarily from that module you're testing at.
There is a bulletin on the XY101A connector, but service info has you remove the battery, air intake system, and battery tray for the repair, due to water intrusion at that connector,
but for the record, I don't recommend going and looking for the connector or disconnecting any electrical connectors or systems on this vehicle. And Do Not touch any bright orange wiring or connectors, those are the High Voltage wiring,
This bulletin has specific instructions for a dealership to reseal this connector and it looks like a grounding location as well. But you're not getting any of the codes for this TSB anyway, below is a section of it.
Apr 24, 2024 at 9:40 AM
