I have replaced the A/C compressor; the climate control unit and the A/C compressor clutch will not work unless the relay is jumped. I think it's pins 85 and 30 that are being jumped but I'll have to check to be sure. I know for a fact I'm not getting a ground in pin 85 which I'm guessing activates the ac clutch. Also, the A/C light on the climate control only blinks 3 times when pressed to turn the A/C on. When using a scan tool the A/C can be requested on and it the compressor clutch will engage.
Aug 15, 2023 at 9:38 AM
