Hello, I have a Classic Auto Air A/C system that I installed in my 1970 C10 around 12 years ago. (https://www.classicautoair.com/shop/complete-ac-systems/1970-chevy-pickup-truck-air-conditioning-system/). I am having trouble finding the source of an issue that keeps it from getting cold. (Below 60) The system has a new compressor and drier and holds both vacuum and pressure. The manual says to charge with 24oz of 134a and pressures should be 10-25 on the low side and 150-274 on the high. I'm at 22 on the low and around 210 on the high. The air temperature outside is around 100 degrees.
The compressor used to cycle on and off and now it does not. I have a low side pressure switch that is functioning, and the clutch did not engage until the first can of 134a was being introduced. The is no high side switch and I believe the cycling is controlled by the expansion valve? And I also suspect this might be the issue.
So, before I start the long task of getting the box out, I wanted to get some expert advice of what's left to trouble shoot. Thanks in advance.
Aug 18, 2023 at 5:19 PM
