It sounds like there is a problem with the mode door actuator. This actuator is what changes the airflow direction.
To get you started on the repair, take a look through this link. It covers in general how to repair this issue.
https://www.2carpros.com/articles/air-vents-stay-in-the-defrost-position
Now, this vehicle has a mode door actuator for the defroster door and one for the floor and vent. Here is what I would suggest. Remove the floor/vent actuator and see if it responds when you change airflow directions. Do the same with the defroster actuator if the other one doesn't work.
I attached directions for the removal and replacement of both in the attachments below. The defroster mode actuator is behind the glove box. The floor/vent actuator is on the left side of the instrument panel. Both are attached to the HVAC unit.
See pics below.
Oct 13, 2021 at 6:36 PM
