AC not working properly
2002 JEEP GRAND CHEROKEE
208,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
PARIS JAMES
AC switch does not light up and clutch not spinning. Also, AC does not blow cold air.
Jul 3, 2018 at 11:47 PM
Good morning.
Did you check the fuses for power on both sides with a test light?
If you have a test light we can do some checks to se if it has the correct power to start the compressor.
Also, do you know if it has Freon in the system?
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
https://www.2carpros.com/articles/how-a-car-fuse-works
Jul 4, 2018 at 5:10 AM
