Isn't it funny, for my '72 Challenger, the entire wiring diagram fits on two pages of service manuals. Today it takes two pages of diagrams to cover one taillight, and the cars are no more reliable.
Also be aware, for decades, Chrysler was the world's leader in innovations that benefited car owners. The list includes things like the first anti-lock brakes, (1969), first lock-up torque converter, (1977), first computer-controlled automatic transmission, (1989), first electronic voltage regulator, (1970), and first "AC generator", (1960. They copyrighted the term "alternator"). My reason for bringing this up is they were also the first to have a true electronic ignition system, but that showed up in 1972, but only on the Dodges. They used it on Plymouths and Chryslers in 1973. While this new diagram is not intuitively obvious, after following it for a couple of minutes, I'm pretty sure it is different from what I had. That's why I'm remembering it differently. The Scamp is the 2-door version of the Plymouth Valiant. I had a couple of Swingers and a Demon, the 2-door versions of the Dodge Dart.
The other thing that is noteworthy at the time was the Plymouths were the low-cost models with options you could add, including trim packages. The Dodges were higher cost because many of those options were included automatically, then, the options you could add to the Dodges were included automatically on the Chrysler models, plus the Chryslers offered some things you just couldn't get on the Plymouths and Dodges. Mostly that amounted to trim packages like leather seats or velour cloth.
Another exciting bit of trivia to add to your memory banks is starting with '72 models, every dark blue wire under the hood had 12 volts switched onto it with the ignition switch in the "run" position. That included feeding things like the alternator field, electric choke heater, ignition ballast resistor, and things like that. That held true through at least the 1989 models, except a few truck models used red wires for the switched 12 volt circuit under the hood. I see dark blue wires on your diagram, but not in that function. Regardless, I traced what I think is the current path to run the compressor clutch. I'm not sure what they're doing with the vacuum switch at the top left, but they did use them to turn the compressor off when vacuum was low. That occurs when passing a freight train, going up a steep hill, and you need every ounce of horsepower you can get to move the car. You can get along for those few seconds without the compressor.
Even if I'm interpreting that switch wrong, if you start at the lower left where it says, "Cavity "A" to air conditioning clutch", then work your way back to the "Temperature control switch", you know you gotta have continuity through that switch for current to flow to the clutch coil. Given the nifty photo you posted of your switch, and the way it's labeled here, it is the control unit that regulates system operation. It's not a safety cutout or anything like that. You can safely bypass it temporarily with a jumper wire, but that wire should be fat enough to handle at least five amps. A 14 gauge wire can do that.
You originally mentioned you found 12 volts on one side of that switch, but not the other side. Logic would dictate the switch is open, but check that again with everything connected. Now, if you find you have close to 0 volts on both wires, the high resistance is in the vacuum switch, or, less likely, the wire running back to it. What you would do is keep working your way back to the various test points until you find where you still have 12 volts, and the one next to it where it's missing. I know I'm not explaining that well, so I'll do a better job of it later if it comes to that.
Another fun fact to share with your friends and family is while the AC system was factory-installed, it looks like an aftermarket add-on system by the way it hangs down under the dash. What reminded me of that is when following the diagram back to the power source at the right side of the diagram, it is not coming from a fuse dedicated for the "AC" or "Heater" system. They're using an Accessory terminal in the fuse box. That terminal was often provided for owners who wanted to add a CB radio, tape player, or things like that, and they didn't want you to compromise the tension on the fuse holder terminals by stretching them with an extra wire stuffed in there. It also relieved them of some liability issues if something in the fuse box started a fire. For dealer-installed options, the cruise control would be a better example. Everything came in one package, including the wire harness to connect all the pieces, then the last step was to plug the 12-volt wire into that "Accessory" terminal. You didn't have to rewire the fuse box.
So, to boil down all this great and wondrous information, jump the two terminals on the "Temperature Control Switch", and the compressor should run, but the engine will have to be running so the intake vacuum turns on that vacuum switch. If that works, the next issue is finding a good replacement. I didn't see one listed on Rock Auto. AC in those early years was pretty rare, so finding a used switch in a salvage yard will be hard. I'm in Wisconsin where anything over ten years old is rusted away due to the unnecessary overuse of salt in winter. You'll have better luck down south.
Another resource to consider is a radiator repair shop or a shop that specializes in AC repair. The people there will likely know of some other brand or model that used a similar switch. Don't overlook the dealers too. Every single one of them that has been in business since the '70s or earlier has a lot of "new-old-stock, (NOS) parts covered in dust on the back shelf. You never know what treasures you're going to find there. As a really last resort, I would entertain a notion to take the old switch apart and see if the contacts could be sanded. If they're arced and pitted from repeatedly switching that relatively high current on and off, shining up the contacts will work. Thermal switches operate by means of a bimetallic strip that bends with changes in temperature. Often those strips become brittle or corroded and will lose their spring tension first, then even fall part. There's no fixing that.
Let me know what you find. Meanwhile, I'll keep working on ideas of what might work if you can't find a new switch.
Aug 17, 2024 at 9:25 PM
