Replaced compressor, liquid line, accumulator with switch along with expansion valve. system will not charge, typically 1/4 of the bottle of 11oz 134A the clutch will engage and you will then be able to properly pull your high & low readings but it won't engage. So low side 70ish psi with high side barely 50 psi. I even opened the compressor again and dumped the oil. then read in the event that it had too much oil then pulled vacuumed for nearly 2 hours and tried to recharge it again and it still won't engage.
Dec 29, 2019 at 11:21 PM
