AC system blowing warm air
2000 CHEVROLET MONTE CARLO
180,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
KELLY HELGESTAD
  • 4 POSTS
My AC has correct refrigerant level, clutch engages, blower blows, but still no cold air. Just blows warm air. What are possible failure points I can check?
Sep 24, 2018 at 8:48 PM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
You might want to have the Blend Door Actuators checked for proper function.There two mounted on both the left and right side of the lower heater/-A/C unit. I have attached a tutorial showing what is involved. Hope this helps and feel free to ask any questions.Thanks for using 2CarPros.
Danny-
Sep 24, 2018 at 11:53 PM
KELLY HELGESTAD
  • 4 POSTS
Both blend doors are working correctly. I did notice that the radiator cooling fan did not engage when AC was turned on but when I manually turned them on it made no difference with temperature. Possible low pressure switch?
Sep 29, 2018 at 9:53 AM
DANNY L
  • 5,648 POSTS
Hello again.
Yes, it would be a good idea to test the switch. Let me know what happens. Thanks again for using 2CarPros
Danny-
Sep 29, 2018 at 6:39 PM
KELLY HELGESTAD
  • 4 POSTS
So I tried a new account pressure switch hoping that would solve the problem but it did not work. Fuses good, relays are new, and I am totally out of ideas. Thoughts?
Oct 12, 2018 at 8:21 PM
DANNY L
  • 5,648 POSTS
Hello again.
Do you have access to a manifold gauge set? If so, what are the readings when the compressor is running/cycling? Hope to hear back soon and thanks again for using 2CarPros.
Danny-
Oct 15, 2018 at 3:48 AM
KELLY HELGESTAD
  • 4 POSTS
Low side 42psi high side is 167psi.
Oct 20, 2018 at 7:46 PM
High side sounds low, can you confirm the large refrigerant tube heading out of the firewall is cold with the system on? Turn the system on full cold and wait two minutes then check the line. You might have a compressor that is going out.
This guide might help:
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
Oct 23, 2018 at 11:56 AM
