I just finished installing a new stereo in my 2005 Toyota Tacoma - I had the AC Control unit out because that is how you access the stereo to install a new one.
When I replaced the AC control unit the AC button light and the outside air circulation button light would not light up. I removed the panel and checked to see if the connections were plugged in correctly. All was good there so I unplugged them and I made sure they were lined up correctly and carefully plugged them back in again and still no lights on either switch.
I turned on the vehicle and turned on the AC... no AC defroster only...
I checked a few of the fuses under the secret door on the driverside lower dash. None that I checked were blown. I wasn't sure what each of the fuses were for.
Is there a main fuse blown or is there a fuse inside the unit that needs replacing?
The abbreviations were not something I recognized. Do you know which fuse it could be or am I going to have to look at all of them to see which one is burned out?
Is there a solution for this?
Thanks for your answer,
Best,
Jim
Best,
Jim
Aug 17, 2013 at 12:30 AM
