A friend asked if I would help him find why his A/C is not working so being familiar with freon and cars and agreed to help. My bad! Navigator's are a pain to work on. Anyway, we started by doing a complete pump down, vacuum to 30hg and waited over night to make really sure the vacuum would hold. It did so got 4 12-ounce cans in before it would take anymore. Started the vehicle and turned on the A/C. Nothing, clutch not pulling in. Checked fuse 11 it was good. Hunted for half a day for the clutch relay, located on the driver's side behind and below the headlight. Had to pull the air breather completely out to get to it. Pull the relay and tested good on the coil no short. Did some reading on here and jumped out I think pins 87 and 30 on the relay plug in and had my friend start the truck. Looked and yes, the clutch had engaged so finished putting in the freon, 54 ounces total and watched the pressures for a bit. High side running a little over 200 at idle and some what higher when revved up some.
Turned the truck off and removed the jumper from the battery and tested the voltage pins for the coil. 5.33 volts. ran a jumper to battery negative and tested again between battery jumper and hot pin, 13.25 with the truck running or not running. Left the jumper to battery neg on and plugged in the relay and heard the clutch pull in. Started the truck and ac working. Had my friend turn the ac off on the controls with the truck running but the clutch stays engaged. Turned truck off, removed the jumper from the battery and back to original problem of clutch not pulling in. My question is does the PCM control the relay through the negative wire?
May 9, 2025 at 6:58 PM
