The system should be vacuumed and then recharged. Vacuuming, also known as evacuation, involves removing any air and moisture present in the A/C system. This is important for a couple of reasons.
First, if air remains in the system, it can cause poor cooling performance and potentially damage the compressor. Vacuuming removes the air, ensuring that only refrigerant is present in the system.
Also, moisture is another enemy of an A/C system. If moisture gets into the system, it can react with the refrigerant and form acids that damage the internal components. Additionally, moisture can freeze inside the system, blocking the refrigerant flow.
Here is a link showing how it is done:
joe
Jul 4, 2023 at 11:21 PM
