A/C problems
2003 HYUNDAI SANTA FE
192,000 MILES • 2.4L • 4 CYL
BRIAN KIRKPATRICK
  • 7 POSTS
Problem is just bought the car and it had a new as compressor on the car. about two weeks goes by and the clutch on the compressor went out. I could not get warranty do I forked out the money $400.00 and replaced the whole system. Two weeks goes by and the clutch on the brand new compressor burns out again. I have changed the whole system four times now and still seem to have the same problem. please help.
Aug 28, 2019 at 12:50 PM
Good afternoon.
Can you give me the pressures on the high and low sides when it was running?
Pressure could cause the failure but needs to be confirmed.
Aug 28, 2019 at 1:09 PM
BRIAN KIRKPATRICK
  • 7 POSTS
Pressures are normal 35 to 40 low side 160 to 240 high side.
Aug 28, 2019 at 2:46 PM
BRIAN KIRKPATRICK
  • 7 POSTS
It is not cycle on and off it works fine for about two weeks and burns the magnetic clutch so the power no longer will turn compressor on.
Aug 28, 2019 at 2:48 PM
Okay, what brand compressors are you using?
BRIAN KIRKPATRICK
  • 7 POSTS
Four seasons.
Aug 29, 2019 at 7:55 AM
BRIAN KIRKPATRICK
  • 7 POSTS
They are brand new compressors though.
Okay, if the clutch keeps burning out, can you test the distance between the plate and pulley? It should be .017.
Aug 29, 2019 at 8:30 AM
BRIAN KIRKPATRICK
  • 7 POSTS
Are you trying to tell me that you think that all four brand new compressors are going to have the clutch set wrong not rebuilt compressors but brand new ones?
Sep 3, 2019 at 8:01 PM
BRIAN KIRKPATRICK
  • 7 POSTS
i am sorry but i have been doing A/C for 25 years and i have never run into a car that will burn out a clutch in two weeks every time. i have completely changed the system four times and in between i have flushed the entire system and replaced the dryer and the expansion valve and the last time the condenser.
Sep 3, 2019 at 8:04 PM
Have you checked the voltage to the clutch?
Sep 4, 2019 at 3:31 AM
