Air is blowing warmer on driver side than on pass side when calling for full cold. Does not have dual climate control so as far as i can tell there is only one door actuator. Actuator is working and door moves freely when I took the actuator off and worked it manually. When working manually no change in the problem. I assume the one actuator is suppose to move both doors(if there are 2 doors). Is it possible that what ever connects the 2 doors has failed? Any other suggestions would be apprecitated.
Thx
Thx
Jul 24, 2020 at 11:01 AM
