Blend door actuator location
2013 HYUNDAI ELANTRA
35,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
JACOB CONDRON
  • 4 POSTS
location of the ac blend door actuator? A/C problems.
Jul 2, 2019 at 9:53 AM
Good afternoon,
I attached the procedure and pictures for you for the repair.
Change Vehicle Bookmarks Library Request Conversion Calculator Technician's Reference - Collision
Search vehicle information
Community 27 Create Quote
2013 Hyundai Elantra L4-1.8L
Repair Procedures
Vehicle Heating and Air Conditioning Air Door Actuator / Motor Service and Repair Removal and Replacement Temperature Control Actuator Repair Procedures
REPAIR PROCEDURES
Inspection
1. Ignition "OFF"
2. Disconnect the connector of temperature control actuator.
3. Verify that the temperature control actuator operates to the hot position when connecting 12V to the terminal 3 and grounding terminal 7
Verify that the temperature control actuator operates to the cool position when connecting in the reverse.
[Drive]
4. Check the voltage between terminals 4and 5 (Drive)
Specification
[Passenger]
5. Check the voltage between terminals 4 and 5 (Passenger)
Specification
It will feedback current position of actuator to controls.
6. If the measured voltage is not specification, substitute with a known-good temperature control actuator and check for proper operation.
7. If the problem is corrected, replace the temperature control actuator.
Replacement
1. Disconnect the negative (-) battery terminal.
2. Using the screwdriver, remove the center garnish (A).
3. Loosen the mounting remove the console upper cover (A).
4. Remove the center console assembly.
5. Loosen the mounting nut and clip remove the extension cover (A).
6. Remove the side cover (A).
7. Disconnect the fuse box cover (A).
8. Loosen the mounting screw and then remove the crash pad lower cover (B).
9. Disconnect the diagnosis connector (A).
10. After loosening the mounting bolts, then remove the reinforce panel (A).
11. Remove the shower duct (A).
12. Disconnect the temperature control actuator connector (A)
13. Loosen the mounting screw and then remove the temperature control actuator (B).
14. Remove the side cover (A).
Jul 2, 2019 at 12:27 PM
