The ax compressor clutch only works when jumping pin 30 and 87. It’s charged with the correct amount of Freon. I have tested about as much as I could but I’m not very electrically smart. From what I understand possibly a bad PCM since it’s not grounding pin 85. The wire between them is good, I checked continuity and it was fine. Relay is good, I swapped it with the horn relay and the ac relay from another truck that the ac works. Not sure if I’m missing something easy or if PCM is bad. Would just like to hear the thoughts from someone that knows more than me.
Thanks
Thanks
Jun 14, 2023 at 6:15 PM
