You will need a test light or voltmeter to some checks.
I attached a wiring diagram. Remove the relay and turn the key on. You should have power to 2 terminals.
Jul 12, 2019 at 5:07 PM
RAYMONVEE
MEMBER
I put 32 oz of Freon.
Jul 13, 2019 at 12:41 PM
RAYMONVEE
MEMBER
I just ran a test and it has 32 psi on low and 150 on high side. I put a new door blend actuated on but it doesn’t seem to be working right. It blows air through all the vents and the heater and defrost works but only on high.
Jul 13, 2019 at 1:37 PM
CERTIFIED EXPERT
The blower is from the blower resistor. That should take care of that.
Are you still using the paper clip? If you are, replace the switch you are bypassing.
The high side is high. It should be 25-30 lbs. Try spraying some water from your garden hose on the condenser and see if the air gets cold.
Image (Click to enlarge)
Jul 13, 2019 at 3:18 PM
RAYMONVEE
MEMBER
I replaced the A/C relay and the 10 amp fuse. Still didn’t work also turned swamp cooler directly on the condenser. Could it be my brand new orifice valve?
Jul 14, 2019 at 9:04 AM
CERTIFIED EXPERT
Again, does it still not run without the paper clip?
No to the orifice tube.
Do you have a test light or voltmeter to do some tests at the relay?
Jul 14, 2019 at 12:53 PM
RAYMONVEE
MEMBER
It still needs the paper clip to run. Used a voltmeter to 2 terminals and got plenty voltage “12”.. tested the diode it is good.. getting power to both switches on the compressor, the one in front by the clutch and the one in back of the compressor.
Jul 14, 2019 at 1:11 PM
CERTIFIED EXPERT
Did you replace the low-pressure switch as I post a while back?
Jul 14, 2019 at 1:12 PM
RAYMONVEE
MEMBER
It’s also new, yes I did.
Jul 14, 2019 at 1:51 PM
CERTIFIED EXPERT
If you have to bypass the switch with a paper clip the switch is bad unless the low side pressure is below 20 lbs.
If the pressure is at 32, as you posted, then the new switch may be bad.
Jul 14, 2019 at 1:56 PM
RAYMONVEE
MEMBER
Thanks Roy. I have a cheap set of hoses so maybe the gauges are off or I’m not reading them right. but the book says it takes 32 oz of Freon so I put 3 12 oz cans and left a little in the can to make up for 4 oz that I didn’t need.
Jul 14, 2019 at 2:29 PM
CERTIFIED EXPERT
You are welcome.
Always glad to help.
Jul 14, 2019 at 2:32 PM
RAYMONVEE
MEMBER
I was bypassing the relay in the fuse box to get it going. Do you think it would damage the compressor to leav the paper clip in and drive it like that?
Jul 14, 2019 at 2:46 PM
CERTIFIED EXPERT
No, you are compensating for a problem and may create even more issue.
