A/C not working after A/C refill
2007 MERCEDES BENZ E350
150,000 MILES • 6 CYL • AUTOMATIC
TONYSCARE350
I recharged my car's listed above A/C system yesterday with AC pro AC recharge.but my A/C still does not blow any cold air the.The air from the outside come through the vents though.I tried all functions of the A/C and still no cold air.Is it a fuse problem? or a reset button that I need to push? I really need some help with this A/C problem because I have a 4 year old.So having A/C during summer is a must.Thanks so much for your help.
Jul 12, 2020 at 6:09 AM
This could be a fuse but we need to start at the beginning which is checking to see if the compressor even comes on.
If not, then we will most likely move on to checking for power. However, if the compressor is coming on then we will need to check pressures. So in other words we need to determine if this is coming on to know which way to go with the next step.
Here is a guide that will help with this. Thanks
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
Jul 12, 2020 at 8:30 AM
