A/C not working
2010 NISSAN PATHFINDER
136,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
LENNIKA
Can’t find the A/C relay. the A/C blows hot air and the air clutch is not catching.
Jul 2, 2020 at 10:41 AM
Good afternoon,
Did you check the freon pressures? If they are low, the compressor will not come on.
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
I attached a wiring diagram of the system for you. If you have a test light, we can do some voltage checks to see why the clutch is not engaging.
As far as the relay, it cannot be accessed. It is part of a module.
Note: The compressor relay or A/C relay is located in the IPDM (intelligent power distribution module) and is not serviceable.
Jul 2, 2020 at 11:45 AM
