Air Conditioning problem
1998 Kia Sportage 4 cyl Two Wheel Drive Automatic
lOW SIDE =40 PSI
HIGH SIDE=240 PSI
outside temp (FLORIDA)=92 degrees (F)
topped freon off since it was not blowing cold at all; pressures read as above with blower on HIGH.
THE low side ac pipe coming out of engine firewall(evaporator) is warm, other high side pie (ac line ) is HOT to touch. What could be worng..BOTH fans come on (ac condensor and radiator fan..car NOt overheating)..
problem seems intermittent. Sometimes car will blow cold air (only when pipe coming out of evaporator(low side is cool to touch and sweating; otherwise, pipe gets hot again and will not cool car.
Both fans(AC CONDENSOR and radiator fan turn on). Car not overheating..PLEASE advise, thanks
Apr 9, 2020 at 12:03 PM
(Merged)
