THERE ARE SO MANY THINGS THAT COULD KEEP THE DOOR(S) FROM MOVING
IT COULD BE MECHANICAL (LIKE A DOOR BROKEN OR A LINKAGE FROM AN ACTUATOR POPPED LOOSE OR A FRIED ACTUATOR)
AS FAR AS ELECTRICAL OR ELECTRONIC GOES BODY MODULE, THE PCM, AND A BUNCH OF OTHER INBETWEENS
UNTIL IT IS DIAGNOSED, THERE'S NO WAY OF ATTEMPTING A QUOTE (SORRY :-( )
HERE'S MY LAST DITCH EFFORT TO GET YOU OUT CHEAP!
I PONDERED THRU "PRODEMAND"s WIRE DIAGRAMS FOR YOUR VEHICLE
BOTH MANUAL AND AUTO A/C HAD THE SAME FUSES FOR THE SYSTEM
17, 23, 21,
AND 19 (WHICH WAS THE ONLY EXTRA ON THE AUTOMATIC SYSTEM)(WON'T HURT TO CHECK 19 REGARDLESS)
THESE FOUR FUSES ARE ON THE LEFT END OF THE DASH
UNDER THE HOOD
CHECK "B" AND "E"
LEFT SIDE OF THE ENGINE COMPARTMENT
THAT IS EVERYTHING I COULD FIND, FUSE-WISE, TO THE HVAC
RETURN WITH GOOD NEWS!
THE MEDIC
Apr 20, 2016 at 7:15 PM
