A/C mostly blowing through floor vent very little through dash vents?
2001 DODGE RAM
259,000 MILES • 3.9L • V6 • 2WD • MANUAL
JEFF HULL
I have a broke what I believe is the mode door that is visible from the floor board on the passenger side when laying on your back looking up at the HVAC. See pic. I need to know how to replace that door with out pulling the dash.
Thanks,
J
Sep 9, 2025 at 4:09 AM
I don't think the actuator is the problem, this is a vacuum operated system thank defaults to the position you are describing when the system losses vacuum, I would lift the hood and check the small plastic vacuum tube for the engine, to the reservoir and to the firewall, this i normally where it brakes. Please use this guide to help fix it:
https://www.2carpros.com/articles/air-vents-stay-in-the-defrost-position
Sep 9, 2025 at 5:13 PM
