What is the exact problem you are having and with the new compressor was the correct weight of refrigerant installed using the correct equipment, or was it filled with a top up can?
Jun 14, 2017 at 4:33 AM
CERTIFIED EXPERT
The pressure switch is on the hose from the compressor, here is a diagram (below) Please let us know if you need anything else to get the problem fixed. CLICK IMAGE BELOW
