A/C port location
1996 FORD ASPIRE
114,000 MILES
WINK63
  • 7 POSTS
Need to find location of port to charge A/C.
Apr 19, 2019 at 5:39 PM
STEVE W.
  • 15,113 POSTS
Hello and welcome to 2CarPros.
The low side port is the one in the larger line in the system. Should be near the firewall if I remember correctly. The high side port is up front near the hood latch. Why do you think that a low charge is the problem? It's possible but if the system is already charged you could cause a dangerous situation. Do you have a gauge set to test the pressures and allow you to vacuum the system down if it is empty?
Apr 19, 2019 at 6:43 PM
WINK63
  • 7 POSTS
Yes i do have a gauge.
Apr 19, 2019 at 7:53 PM
STEVE W.
  • 15,113 POSTS
What do the high and low pressures read if you just put the gauge set on? Is the compressor clutch cycling at all?
Apr 20, 2019 at 5:51 AM
WINK63
  • 7 POSTS
Yes.
Apr 20, 2019 at 7:20 AM
STEVE W.
  • 15,113 POSTS
With the clutch cycling I would check the pressures before adding anything. What is the reason for adding? No AC in the car or?
Apr 20, 2019 at 8:43 AM
WINK63
  • 7 POSTS
Blows just not very cold.
Apr 20, 2019 at 11:17 AM
STEVE W.
  • 15,113 POSTS
That could be a low charge but it could also be a blend door not sealing fully. I would put the gauge set on and get the running pressures. Then go from there.
Apr 20, 2019 at 2:10 PM
WINK63
  • 7 POSTS
Okay, thanks.
Apr 20, 2019 at 4:13 PM
STEVE W. is one of our best! Please let us know what you find. We are interested to see what it is.
Apr 22, 2019 at 4:53 PM
WINK63
  • 7 POSTS
Sure will.
Apr 23, 2019 at 1:06 AM
