AC light not coming on
2008 DODGE RAM
200,000 MILES • 6.7L • 6 CYL • 4WD • MANUAL
RANDY MENZER
When I go to turn my AC on it comes on but when I press the button to cut the AC on the light does not come on. I am wondering if there is a fuse or a relay switch that needs to be changed?
Sep 12, 2018 at 12:04 PM
STEVE W.
  • 15,113 POSTS
Welcome to 2CarPros.
Okay, so the AC works but the indicator that says it is on does not come on correct? If that is the problem it is likely just the LED in the unit has failed. If you mean you turn on the AC and there is no light and the AC does not come on there are multiple items that can cause that. Please reply with which is your issue and we can see what your options are. Thank you.
Apr 23, 2021 at 9:44 AM
