Back history: I had an electrical problem with my A/C system. I had evacuated A/C system and it had -30 of vacuum on gauge held for over an hour so I had no leaks. I went to charge it, and nothing happened. I tried to jump relay for the A/C compressor, and nothing happened. By this time, I had put two cans in. By this time, I had put two cans in. I stopped, I changed the engine harness because of that and some other electrical problems. The truck is running fine now.
Now it’s all ready to charge but from the system not working previously there is a leak.
My question is, how should I find leak? I have light and an A/C leak detector. Do I need to put more oil?
From pressure building up when A/C compressor was not working where most likely do you think leak occurred. Just need some direction how to proceed.
Apr 27, 2022 at 5:48 AM
