Replaced compressor, expansion valve, condenser/accumulator assembly and cycle switch. Flushed system when apart. Fans work when A/C is activated. Problem is this. Car blows around 55 degrees with an outside temperature of 87 ish. When at idle it blows around 60. Why would it not be colder than that? Just seems the idle temperature is just not cold enough. Even the driving temperature should be colder, at least I would think so. Just not sure where to go from here. Thank you for any advice you can give me. Steven Gilmore
Jul 26, 2019 at 11:44 PM
