A/C issue, how to replace the 50a fuse?
2009 LEXUS ES 350
130,000 MILES • V6 • AUTOMATIC
DIVIDES
  • 903 POSTS
Friend if mine's car. His A/C was not cold and fan not running when i checked. Lexus said that the 50a fuse is blown and needs to be replaced and that the fuse box needs to be disassembled to do that. i want to change it for him. Any instructions on how? They are asking too much for labor. They said no power going to magnetic clutch relay or the fans.
Aug 15, 2021 at 8:01 PM
SQM
  • 6,383 POSTS
That fuse is located in the fuse box under the hood. That fuse box is located close to the driver side fender (see diagrams).
The fuse number is 34 (50A).
You will have to remove the plastic covers for the engine to get to the fuse box.
After that you simply take off the cover the replace the fuse. You do want to make sure that the fuse is indeed faulty.
https://youtu.be/ZBtpZx7BSzc
Thank you.
Aug 15, 2021 at 11:05 PM
DIVIDES
  • 903 POSTS
Fuse was faulty, after i installed the new one i saw some smoke coming out of the fuse box especially around the relays. Removed the negative immediately, there is some blemish around the new fuse as well, right in the middle, switched couple of relays, turned it on all okay, started , fan works, air is good. I don't know what they did when they fixed the car after the accident, something in my gut tells me something isn't right.
Aug 20, 2021 at 6:40 PM
SQM
  • 6,383 POSTS
It could be for a wire being pinched or exposed or shorted. It will be difficult to know which one without tracing the wiring harness for the A/C system. Might even have to dig even deeper with other harnesses. As many of these components are connected and can impact one another.
Aug 20, 2021 at 7:00 PM
DIVIDES
  • 903 POSTS
Ya, am aware, i let them know. i told them to sell it, they can be having more issues in the future.
Aug 20, 2021 at 7:04 PM
SQM
  • 6,383 POSTS
That's right having an electric gremlin can be very challenging.
Aug 20, 2021 at 9:18 PM
DIVIDES
  • 903 POSTS
Car is not working this morning, strange. Jumped it and went for a rode all good. Alternator charging 13.7v. Came back from a 5 mile drive, parked it. Turned it off and started twice no problem, left it for 30 minutes came back and its totally not working. Battery .82v, what the heck. How is that possible? This is the fuse cover. Anything you suspect that causes that?
Aug 21, 2021 at 10:48 AM
DIVIDES
  • 903 POSTS
Also just kept it running and looking at scanner voltage is 13.1.
Aug 21, 2021 at 11:12 AM
DIVIDES
  • 903 POSTS
After running for a while still at 13.2. Turned it off and kept voltmeter connected to battery. Watched it drop slowly. In 2 minutes dropped from 12.2 to 11.90.
Aug 21, 2021 at 11:23 AM
SQM
  • 6,383 POSTS
It appears that the vehicle has an excessive amount of parasitic draw.
A parasitic draw (current drain), can be caused by a number of electrical equipment. It could be as simple as a glove box or a trunk light staying on. It can also happen for a short in a electrical circuit like a window switch etc.
Check out these videos for some helpful guide:
https://youtu.be/z5F7WpgjaRs
https://www.2carpros.com/articles/car-battery-dead-overnight
Aug 21, 2021 at 11:35 AM
DIVIDES
  • 903 POSTS
Ya, I checked all the lights and none are on. I doubt it is a light because the drain is quick. It may be a short due to the smoke that I saw when I installed the ac fuse. One thing after another with this car.
Aug 21, 2021 at 11:53 AM
SQM
  • 6,383 POSTS
It does sound like a short. Try removing that 50A fuse and see if the current drain still exists. It could the harness for that fuse.
Aug 21, 2021 at 3:02 PM
