A/C not cooling as good when stopped?
2011 SUBARU IMPREZA
117,000 MILES • 4 CYL • 4WD • AUTOMATIC
BHAMDOC1973
  • 2,008 POSTS
car would start and ac would be great for few miles, then the fast cycling of compressor would start and would not cool as good when stopped. The shop says expansion valve is leaking and causing the compressor to overheat so they recommend a compressor, expansion valve, and a dryer, which comes to be too high for me to spend on this car. Where is the expansion valve located and how to replace it? I want to try it myself. I have done many A/C compressors and other parts myself before.
Sep 28, 2023 at 6:06 AM
If the expansion valve is leaking that would cause the problem so let's try that rift, this video can help, and I have included the location of the expansion valve which is near the firewall and how to replace it.
https://youtu.be/4EqdrBVb0sY?si=Yf_rtTRVPxFbyRnm
Check out the images (below). Please let us know how it goes.
Sep 28, 2023 at 10:59 AM
BHAMDOC1973
  • 2,008 POSTS
Why would a bad vave cause the compressor to heat up?
Sep 28, 2023 at 7:02 PM
If it is clogged or the valve is closed down it can cause the compressor to over work itself.
Sep 29, 2023 at 10:28 AM
BHAMDOC1973
  • 2,008 POSTS
I see. I don't understand what the expansion valve does that's why i asked.
Sep 29, 2023 at 10:44 AM
Sure, it takes a high-pressure refrigerant, and it passes through the valve to get the cold air while turning the refrigerant into a low pressure gas. Please go over this guide with will help you understand how the system works:
https://www.2carpros.com/articles/how-a-car-air-conditioner-works
Oct 2, 2023 at 9:20 AM
BHAMDOC1973
  • 2,008 POSTS
Replaced it and all is good. Thanks
Oct 3, 2023 at 4:32 PM
Thanks for letting us know, we are here to help, please use 2CarPros anytime.
Oct 4, 2023 at 8:05 AM
