The passenger side A/C blowing warm air?
2006 BMW 325
165,000 MILES • 6 CYL • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,008 POSTS
The driver's side is okay, passenger is warm. If you drive it gets a minor improvement on both sides, am suspecting a weak compressor, checked freon level and its full, removed some and then tried again I can't add a lot, its full. fan works, these have non electric fans, I also see a bit of a wobble while the compressor is running, also it does not cycle on and off, it's on always so it's fine, and like I said only the driver side is cold, but it's not where it should be.
Aug 30, 2024 at 3:03 PM
I don't think this compressor has a clutch; it is internally valved. What are the high and low side pressures? This video will help you:
https://youtu.be/4EqdrBVb0sY?si=FTo0fDvLCYSkEneT
Aug 31, 2024 at 4:41 PM
BHAMDOC1973
  • 2,008 POSTS
Looks like it has a clutch, or something cause the outside clutch kicks on when you turn the A/C on. Gauges went bad and I am relying on two individual ones which both show the level is full. I am suspecting the heater control valve.
Aug 31, 2024 at 4:56 PM
Yep, it looks like a clutch, but it is not, this system has a refrigerant compensation valve. Does it show the high side pressure? Check out the images (below).
Sep 1, 2024 at 9:40 AM
BHAMDOC1973
  • 2,008 POSTS
My gauge not working.
Sep 1, 2024 at 9:50 AM
We need to get a working gauge, or we will be guessing.
Sep 1, 2024 at 10:54 AM
BHAMDOC1973
  • 2,008 POSTS
I'll see if i can find one.
Sep 6, 2024 at 1:32 PM
Okay, let me know.
Sep 6, 2024 at 5:53 PM
