A/C, what should the low and high numbers be on this car when warm?
2010 CHEVROLET COBALT
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
DIVIDES
  • 903 POSTS
Driver is cool, passenger is flat, fan running, compressor turning. I see both high and low at 90, i suspect a weak compressor. does that sound right ?
May 8, 2021 at 12:04 PM
Good evening,
The high side should be 2 times ambient temperature or out air and the low side should be 25-30 pounds rock solid.
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
May 8, 2021 at 5:28 PM
DIVIDES
  • 903 POSTS
I see. Why is it that some cars are normal or should be at 45?
Also, why does a weak compressor cause the low side to go high?
May 8, 2021 at 6:01 PM
45 is too high. It should be 25 to 30.
No, a weak compressor will not build pressure.
The 90 on both indicates a possible compressor. If the compressor is engaged then it needs a compressor.
https://www.2carpros.com/articles/replace-air-conditioner-compressor
I attached the procedure for the compressor replacement.
I also attached the wiring diagram for the compressor in case it does not engage.
May 8, 2021 at 6:11 PM
DIVIDES
  • 903 POSTS
Yes, it does engage. But am trying to understand the logic behind it. If it's at 90 on low side means not building pressure, but the pressure is high so how is that?
May 8, 2021 at 6:13 PM
When the system is not working, the pressures are called static. Those pressures should be equal on both the high and low sides and within 5 degrees of outside temperature.
May 8, 2021 at 6:17 PM
