A/C and heating unit
2004 INFINITI QX56
222,000 MILES • 0.5L • V8 • 4WD • MANUAL
ROBERT SWAN
  • 8 POSTS
When I turn my unit on I only get heat or air blowing in the back and not from the front vents.
Jan 30, 2018 at 5:58 AM
It sounds like you have a front blower motor that is not working. If you turn the rear air off do you not hear any fan running up front? If so I would start by checking the fuses. Here is a guide and the fuse panel diagrams to help us figure out whats wrong. Here are the complete fuse panel and relay location diagrams for you (below).
Check fuses number 8 and 19.
Jan 31, 2018 at 1:52 PM
ROBERT SWAN
  • 8 POSTS
The fan was just stuck, so I sprayed a little wd40 and it’s back to working. Thanks for your time and patience with my problem. I also have another situation with my vehicle if you can help me with it. I’m hear a scrubbing noise coming from the rear driver side whenever I go into a curve and the pressure and weight of the vehicle is on that side. What causes that and is it expensive to fix. And this is the same vehicle.
Feb 8, 2018 at 6:45 AM
Please post your new question here
Feb 8, 2018 at 9:39 AM
