AC/Heating control panel
2000 HONDA ACCORD
300,000 MILES • 4 CYL • FWD • AUTOMATIC
JAMIELYNNG
I have replaced the control panel already and it seemed to work fine for about two weeks. Now the lights will go off on the control panel and you cannot change the temp. Or anything nothing will work on it. It still blows you just can't use ac and it is going to blow on whatever temp it was on. Sometimes it will just come on out of the blue but it can go for days with nothing.
Apr 7, 2016 at 1:50 PM
HMAC300
  • 48,601 POSTS
if you didn't have it programmed to your car is the problem a pro will have to do that.
Apr 8, 2016 at 7:35 AM
JAMIELYNNG
In don't believe that is the problem. If it needed to be programmed i dont think it would work at all. I recently took the control panel back out took the back cover off and it seems as if there is a problem in the wiring harness its like it is not connected good or maybe it has gotten worn out. But if i push in on the climate control knob it will come on then it may stay on all day or it may just blink out in ten minutes. I have seen lots of videos on you tube of people having the same problem but nobody ha a resolution for me.
Apr 21, 2016 at 11:15 AM
HMAC300
  • 48,601 POSTS
well I can only tell your what my opinion is of your problem and until you get it scanned for codes then you won't really know especially if this is auto temp control where you set the temperature.
Apr 21, 2016 at 12:28 PM
