When car is cold, the airflow in the heating system is good, but sometimes with good and warm engine the air flow shuts down. the blower motor runs at full speed, but still no air coming out of the vents. Even if i change the temperature too cold the air flow is bad. I have changed three servo motors, resistance for the blower motor, both thermistors and head unit. when i run the check A/C for fault codes, it sometimes come up with code 21 and 24. sometimes it can work almost okay for days (still a little weak air flow i imagine) suddenly it turns bad again. when it is not working i have heard a strange sound from somewhere in the compartment area when the heater starts or when i turn off the ignition. (squeaking sound)
Hope you can give me some tips about what to do, because i am running out of good ideas regarding to how to find the fault.
Best regards, Asmund
Mar 18, 2019 at 3:29 PM
