I started working on my car and checked it out and it was showing that I had a blockage I took the orfice tube out and it was stopped up really bad. I changed it and also change the accumulator. I tried to put Freon in it after that but I first vacuum to system down. when I tried to put Freon in it it jumped up high really quick like there was still a blockage. I do not know what else could be blocked in the system the AC pump is coming on but for some reason another it takes very little Freon for the gauge to jump up really high. could you tell me even though the compressor is coming on if it still could be bad if not could you tell me where else to check for a blockage?
May 21, 2017 at 7:42 AM
