On my vehicle listed above, after 15 minutes or so, it appears the A/C evaporator is freezing up. The compressor is not cycling off and on. It does shut if if you it off. Also, lots of water leaking from the Evap box under the car. Someone said it is the Evaporator Temperature Sensor, but I cannot find reference to it for a 2007 anywhere. Is there one on the vehicle listed above? Where is it and can it be changed?
Thank you for your time and help.
Kevin
Kevin
Jan 2, 2021 at 6:00 PM
