When you say control panel, I assume you are talking about the buttons that your press shown in the last attachment. Or do you mean the control module? The control module does require a procedure run after replacement. I attached the process. The control buttons on the dash do not require any programming after replacement.
Hopefully this helps. Thanks
May 27, 2020 at 6:14 PM
