I had made a return post but it seems to have disappeared.
I forgot to mention to you and the shop the truck was just in...
When truck is cold (morning start or after sitting) if I rev the motor rpm's stall at 1,500 rpm's, let off throttle, throttle back up and they will rise as high as demand with a slight jerk/noise like something kicks in again around 1,500 rpm's? It is hard to explain?
It is a standard six speed. So I guess I don't notice it if I just start mashing gears?
Fca?
The mechanic said my injection pump was good? Did he check actual pressure vs demanded?
I can only see actual fuel pressure, I assume the reading is from the rail pressure sensor. (6800-7300psi at idle)
I did do test the fca default by unplugging it fuel pressure jumped to maximum 26000 something psi, in 22 seconds it dropped back to normal idle pressure. I understand that this isn't a true test of the Fca.
What bugs me is;.
before injectors 19- 20 mpg
After injectors 15 mpg
Before new lift pump 15mpg.
After new lift pump 19-20mpg
Monday tow 11.7 mpg & throw soft fan clutch code
Replace fan clutch still 15mpg
The mpgs are off the dummy meter / overhead. I have hand calculated and its 2- 2.5 less.
Thanks for your time.
May 13, 2021 at 12:13 PM
(Merged)
